Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP Trunk with CUBE
moath.almogbel
We have  CUCM 8.6.2 and 3945 router with MGCP controlled PRI's for PSTN Access. We need to connect also to a new provider using SIP
for incoming/outgoing SIP calls.
So I have configured CUBE as per the documents available but cannot place an outgoing call using SIP to the SIP Provider.
The setup is:  CUCM---> SIP Trunk ---> CUBE ---> SIP ---> SIP Provider.
I am new to CUBE so I am attaching ccsip debug and ccapi debug, also the sh run.
any help is appreciated.
Thanks!
2 Accepted Solutions
Chris Deren
You are not getting anything back from your SIP provider, can you ping 80.90.160.221? Are you sure this is the Proxy IP address? Does the trunk perhaps require authentication?
Chris
Moath,
Now we can conclude that we have a network problem with your service provider ip address...From the logs
005747: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x1C4B35C, connid=4state to pending
005748: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:80.90.160.221, port:5060)
005749: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 57
005750: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionFailed: context=0x1E80170
005751: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnFailed: gConnTab=0x1E80170, addr=80.90.160.221, port=5060, local_addr = 10.0.128.11, transport=TCP
005752: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x1C4B35C,addr=80.90.160.221, port=5060
005753: Feb  2 11:36:51.621: //32/7E0207000000/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=1
005754: Feb  2 11:36:51.621: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting TCP conn close for addr=80.90.160.221, port=5060, local_addr=10.0.128.11, connid=4 ++++++++++++++++++++++++++++++++++++++++++++
"CUBE is unable to create either a TCP connection or a UDP connection to the destination ip address 80.90.160.221.
The gateway will not send an invote until it first of all establish a connection to the far end device either via UDP or TCP.
So you need to first of all confirm that this IP address is the right ip address from your provider. You also need to confirm if the port they are using for signalling is 5060. Some providers use different port numbers.
If there is a firewall between your gateway and the provider, you need to check that it allows your local ip and port.
These are your action points. Dont forget to rate any helpful post.
Once you have spoken to your provider please update me on the outcome of your discussion with them
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
20 Replies 20
Chris Deren
Chris
Thank you Chris for your reply.
Yes I am able to ping it and this is the address I got from the provider and they told me they authenticate only using the IP address.
VG-1#ping 80.90.160.221
Sending 5, 100-byte ICMP Echos to 80.90.160.221, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
By the way, I am connected to the provider throught a WAN (not point to point) does this make any difference?
Also can you show me the part of the trace the tells I am not getting any thing from provider so that I can raise it with them.
One more thing, did you find my config is correct? is there any advices/changes that I shoud consider.
Thanks Alot for your help
Moath,
Here is what I see...
You have a sip trunk configured from CUCM to your gateway. But your inbound dial-peer for the called number is h323...
dial-peer voice 10 voip
incoming called-number 0796260696
This wont work and thats why you are getting network out of order..
To resolve this configure this..
session protocol sipv2
dtmf-relay rtp-nte
no vad
Do another test call and if yous till have issues please send only debug ccsip message and debug voip ccapi inout. Do not send debug ccsip all..If we need it we will ask later..This is because it is truncating your debugs.
moath.almogbel
Hi aok,
Thank you for your reply,
I have chnaged the dail-peer 10 as you suggested, but still cannot place the call.
attached are the requested debugs.
I really appreciate your help.
Ok,
Lets try this..remove the mode-border element command..you already have allow-connections sip to sip
voice service voip
  no mode border-element
Then send me debug ccsip messages again
Here you go,
Feb  1 23:15:57.587: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0796260696@10.0.128.11:5060 SIP/2.0
Via: SIP/2.0/TCP 10.1.3.12:5060;branch=z9hG4bK114750d9e1fc
From: "PHONE B" <8351>;tag=123088~bda7d047-7f13-4d7c-84b8-3fccaa8c92b0-61321008
To: <0796260696>
Date: Fri, 01 Feb 2013 23:20:41 GMT
Call-ID: fd5bf000-10c14dc9-630-c03010a@10.1.3.12
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <10.1.3.12:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 4250660864-0000065536-0000000926-0201523466
Session-Expires:  1800
P-Asserted-Identity: "PHONE B" <8351>
Remote-Party-ID: "PHONE B" <8351>;party=calling;screen=yes;privacy=off
Contact: <8351>;video;audio;video
Max-Forwards: 69
Content-Length: 0
Feb  1 23:15:57.591: //1/FD5BF0000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <0796260696>
Date: Fri, 01 Feb 2013 23:15:57 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Feb  1 23:15:57.603: //1/FD5BF0000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <0796260696>;tag=28AD8-A27
CSeq: 101 INVITE
Reason: Q.850;cause=38
Content-Length: 0
Feb  1 23:15:57.603: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0796260696@10.0.128.11:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Ok,
CUBE is sending service unavailable...
Lets tidy up a few things... ( i want us to use the same transport protocol and change our dtmf-relay config)
dial-peer voice 11 voip
no session transport tcp---remove this
no dtmf-relay rtp-nte h245-alphanumeric-----------remove this
dtmf-relay rtp-nte---------add this
send debugs again..if it doesnt work then test again and send debug ccsip all
moath.almogbel
Hi aok,
I have updated the dial-peers but still same issue.
attached is the ccsip all debug.
One question, could it be a codec mismatch thing?
Moath,
It is not a codec issue. You have a Socket problem on UDP protocol and I assume it is the same with tcp. The gateway cannot establish a soccket connection to your ITSP. This is why it cant even originate the Invite to it.
What we will do now is to swicth back to tcp and then send me the debug ccsip all again.
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWSocketException: context=0x13C57EC0
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessSocketExceptions: gConnTab=0x13C57EC0, a
ddr=80.90.160.221, port=5060, local_addr=10.0.128.11, connid=3, transport=UDP
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting UDP conn close for addr=80.90.160.221, port=5060, local_addr=10.0.128.11, connid=3
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x13C582A4, connid=3, addr=80.90.160.221, port=5060, local_addr=10.0.128.11, transport=UDP
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type rned: 2 for event 53
Feb  2 00:12:52.323: //-1/xxxxxxxxxxxx/SIP/Error/act_socket_send_msg_failure: Send Error to 80.90.160.221:5060 for transport UDP
Please do this test quickly! I need to sleep
moath.almogbel
Hi aok,
I do appreciate your time and sorry for not replying earlier, but I have fallen sleep also as it was 3:00 AM here
I have updated the transport to tcp, and attached is the new debug.
Thanks alot Again!
Moath good morning..Hope you had some sleep..
Ok here is what I think is going on..because I have not seen this before, I didnt spot it on time..
Your sip trunk is configured to use TCP as the transport protocol. However your inboud dial-peer on gateway is set to use UDP (the default)
Here is an inbound connection from CUCM to the gateway
Feb  2 09:38:32.766: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x1E80170, addr=10.1.3.12, port=53512, local_addr=10.0.128.11, connid=3, transport=TCP
Hence we need to match this on the inbound dial-peer..so configure dial-peer 10 as follows and test again..Please send the debugs too
Good morning aok,
I have updated the dial-peer 10 to use tcp. attached is the debug.
One more thing, what if I changed the SIP trunk from CUCM to CUBE to use UDP instead of TCP, will this solve the problem? shall I try this?
Moath, Lets hold on first and see whats happening. The logs you have sent is incomplete. Please send the full logs...
Aok,
I have done two fresh tests, you can find them attached.
really appreciated.
