SIP-TRUNKING CONFIG FOR SAUDI ARABIA
Amod Joshi
Does anyone know the sip trunk config for Saudi Arabia.
we have bought SIP trunk from Local ISTP, can we get  the configuration guide from ISTP.
what information will ISTP provide to us for the configuration of CUBE.
Any help will be highly appriciated.
46 Replies 46
testeven
Usually the ISP provides the following:
Domain name
Password
User ID
DID ranges
Number of Sessions
SBC and CPE IP address
It depends on the provider, you'll need to check with them.
Tere.
Please rate helpful posts.
Regards, Tere. If you find this post helpful, please rate! :)
Can you send me the basic configuration steps for configuring sip trunk on cube
you can also check these URLs.
http://www.cisco.com/image/gif/paws/99863/cube-config.pdf
https://supportforums.cisco.com/discussion/11955366/cisco-cube-configuration
//Suresh Please rate all the useful posts.
Dear all
I have issues with stc sip line when i try to call from stc mobile  call not response  but when i try to from zain it is working perfectly
Usually called number for calls originated from STC is appended with 011, while calls that originated from other ISP called number comes without 011.
Make sure incoming-called number/ destination number value are set properly on both incoming and outgoing dial-peers. I usually set it as: 0?1?1?44444XX, where 44444XX is an example range.
P.S. you can insert (?) by pressing ctrl+v then release keys and enter (?).
Thank you,
Shadi
Sent from my mobile
make sure you have g711alaw under the sip trunk configuration in CUCM
See attachment
Also try with enabling "Media Termination Point Required"
mohammadadeel
were you able to configure your router, actually i am stuck with router configuration only.
i would appreciate if you can share your configuration file with me.
it would be a great help.
Thanks in Advance.
Hello Mehaomed
Are you going to do integration with STC ?. For me i did many integration on KSA with STC all over KSA .
please rate all useful information
Hi Islam,
Actually i m new to it with no prior experience, i would request you to share any running configuration file for cisco 2900 series router. i received configuration from stc:
Thanks in Advance.
Hello
sure , i will provide you with a perfect configuration which already tested . I have only on question , did STC share with you any infformation about VLAN id to created?. just a question.
no the above mentioned configuration is the only thing i received from STC no vlan ID.
Hi All,
I have a similar situation with STC and no proper response from STC to troubleshoot. Was this issue resolved? I managed to get calls bothways but once AA transfers, the calls gets disconnected :(
Sam.
Mohamed
As per your DID 133459300-133459499, you have to  use range from 9XXX. because your range of your DID ends with 9XXX. If you use 3XX , you will lose the other range which starts with 4XX.
please explain where do i have to use this range? in router or in cucm.
