SIP trunking
Aleksei.Zjabkin
Hi everyone!
I'm putting together one 3945 router. I need to know what else do I need for SIP trunking using Cisco Comminication Express Manager? Below is config:
ProductDescription
CISCO3945-V/K9Cisco 3945 Voice Bundle, PVDM3-64, UC License PAK
SL-39-DATA-K9Data License for Cisco 3900 Series
SL-39-SEC-K9Security License for Cisco 3900 Series
FL-CMECisco Communications Manager Express License
FL-CME-SRST-25Communication Manager Express or SRST - 25 seat license
SM-ES3G-16-PEnhcd EtherSwitch, L2/L3, SM, 16GE, POE
SL-ES3G-16-IPSIP Services License Upgrade 16 Port GE ES3 EtherSwitch
EVM-HD-8FXS/DIDHigh density voice/fax extension module - 8 FXS/DID
NM-HD-2VTwo-slot IP Communications Voice/Fax Network Module
EM-HDA-6FXO6-port voice/fax expansion module - FXO
EM3-HDA-8FXS/DID8-port voice/fax expansion module - FXS and DID
VIC3-2E/MTwo-port Voice Interface Card - E and M
HWIC-1CE1T1-PRI1 port channelized T1/E1 and PRI HWIC
HWIC-2SHDSL2-pair G.SHDSL HWIC
SM-NM-ADPTRNetwork Module Adapter for SM Slot on Cisco 2900, 3900 ISR
CAB-ACEAC Power Cord (Europe), C13, CEE 7, 1.5M
CAB-CONSOLE-USBConsole Cable 6 ft with USB Type A and mini-B
S39UK9-15104MCisco 3925-3945 IOS UNIVERSAL
PWR-3900-ACCisco 3925/3945 AC Power Supply
3900-FANASSYCisco 3925/3945 Fan Assembly (Bezel included)
C3900-SPE150/K9Cisco Services Performance Engine 150 for Cisco 3945 ISR
ISR-CCP-EXPCisco Config Pro Express on Router Flash
MEM-3900-1GB-DEF1GB DRAM (512MB+512MB) for Cisco 3925/3945 ISR (Default)
MEM-CF-256MB256MB Compact Flash for Cisco 1900, 2900, 3900 ISR
PVDM3-6464-channel high-density voice and video DSP module
SL-39-IPB-K9IP Base License for Cisco 3925/3945
SL-39-UC-K9Unified Communication License for   Cisco 3900 Series
Aleksei
Jaime Valencia
There's no license for SIP trunking, as long as you have CME you can do SIP trunks
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Aleksei
