SIP-UA missing
LyRa
Hi all!
We have Cisco 881 routers at the branch offices and only on one of them we've got that problem when sip-ua suddenly disappears:
Reboot solves the problem.
All configuration across routers is the same.
How can i troubleshoot this problem?
8 Replies 8
George Sotiropoulos
Can you check if you use the same IOS as with the rest of the routers?
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Yep, it's 15.4(3)M7.
Can you please post the sip-ua and dial-peers configuration here?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Here is the sip-ua config:
Spoiler
RT-Novosibirsk#sh run | s sip-ua
sip-ua
credentials username 067000 password blablabla realm voip.uiscom.ru
authentication username 067000 password 7 blablabla
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
registrar ipv4:195.211.120.9:9060 expires 900
sip-server ipv4:195.211.120.9:9060
no suspend-resume
And dial-peer configuration:
Spoiler
voice translation-rule 6000
rule 1 /067000/ /9998/
voice translation-rule 67000
rule 1 /.*/ /067000/
voice translation-profile NOVOSIBIRSK-to-PROVIDER
translate calling 67000
voice translation-profile UCCX
translate called 6000
dial-peer voice 1002 voip
description -[OUTGOING TO PSTN]-
translation-profile outgoing NOVOSIBIRSK-to-PROVIDER
destination-pattern .T
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2000 voip
description -[INCOMING FROM PSTN]-
translation-profile incoming UCCX
incoming called-number 067000
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1000 voip
description -[OUTGOING TO CUCM]-
destination-pattern 9998
session target ipv4:172.31.2.15
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description -[OUTGOING TO MSK through CUCM]-
destination-pattern 849[59].......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1004 voip
description -[OUTGOING TO SPB through CUCM]-
destination-pattern 8812.......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1005 voip
description -[OUTGOING TO KRD through CUCM]-
destination-pattern 8861.......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 6103 voip
description -[To CUCM_MSK]-
destination-pattern ....
voice-class codec 1
dtmf-relay rtp-nte
no vad
On registrar configuration, add a refresh ratio timer.
Eg.
registrar ipv4:195.211.120.9:9060 expires 900 refresh-ratio 50
Carlo
Thanks, i'll try that.
Unfortunately, today sip-ua gone missing again :(
Maybe i can retrieve some logs about sip-ua somewhere?
What is the output of show sip-ua statistics? You many need to clear the statistics so you can show new errors.
I'm also thinking that debug ccsip errors or debug ccsip non-call might show what's happening with the sip-ua.
Maren
