sip version for CUCM
adamgibs7
Level 6
Level 6
Dear
I want to setup a sip trunk with XYZ company call manager, I want to know the SIP version supported by CUCM 10, 11,12
2 Accepted Solutions
R0g22
The current SIP version being used every where is 2.0 irrespective of whether it is Cisco or Avaya. RFC 3261 defines it.
Hi there
RFC’s are more commonly known as SIP 1.0 (2543) and SIP 2.0 (3261). Cisco CUCM supports any 3rd party which has got the RFC 3261 compliance. You can get that details from the below guide
  • Third-Party SIP Device (Advanced)-This eight-line SIP device is an RFC3261-compliant phone that is running SIP from third-party companies.
  • Third-Party SIP Device (Basic)-This one-lineSIPdevice is an RFC3261-compliant phone that isrunning SIP from third-party companies
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_0_1/sysConfig/CUCM_BK_C733E983_00_cucm-system-configuration-guide/Configure___Third_Party_SIP_Phones.pdf
SIP details
https://www.whichvoip.com/voip/protocols/sip.htm
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
R0g22
Dear,
Can you share with me a document for the same, that cucm version 10,11,12 support sip version 2.0, The TLS version 1.0,1,1 and 1,2 are different than the sip version, . these are used securing sip trunk,please correct me if I m wrong
thanks
Hi there
SIP details
Hope this Helps
Cheers
Rath!
Dears
thanks for the replies +5 to you both
