06-19-2018 03:29 AM - edited 03-17-2019 01:02 PM
I need to integrate skype with CME for simultaneous ringing feature, like if someone calls on my extension then it rings at skype on the same time as well.
what I have done is as below.
dial-peer voice 3302 voip
translation-profile outgoing SKYPE
destination-pattern 488925..$
notify redirect ip2pots
session protocol sipv2
session target ipv4:10.106.5.58:5068
session transport tcp
incoming called-number 488925..$
voice-class codec 3302
dtmf-relay rtp-nte
no vad
voice translation-rule 4889
rule 1 /4889\(....\)/ /\1/
voice translation-profile SKYPE
translate called 4889
ephone-dn 76
number 2576
label 2576
description 2576
name user-1
mobility
snr 48892576 delay 0 timeout 15
hold-alert 30 originator
Now if I am calling from this skype profile to other skype profiles that works but when i am calling extension from this skype profile it is not working also if i dial extension 2576 it does not rings on skype.
If anyone can help on this please.
06-19-2018 03:30 AM
Codec is
voice class codec 3302
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
06-19-2018 07:48 AM
06-19-2018 08:29 AM
the ephone-dn is associated to a phone which is already registered and working
basically we are having multiple CME/CUCM so that is why we are looking to implement this feature.
ios version is 15.5(3)M2
CME version 10.5
2921 platform
06-24-2018 10:13 PM
still my issue is not solved can you check and advise?
06-25-2018 01:47 PM
06-25-2018 01:54 PM
no it does not goes.
06-25-2018 02:05 PM
06-26-2018 10:33 PM
Hi Nipun,
If I am dialing 48892576 from another ip phone registered on the same call manager as 2576 then it is giving a busy tone, but from other call manager(CME/CUCM) which are having dial-peer for this call manager with destination-pattern as 25.. it is not going thur, attached are the debugs when I called 48892576 from the same call manager, please have a look and let me know what to do.
07-01-2018 05:03 AM
07-01-2018 05:56 AM
Checked the logs .. Gateway seems to be getting SIP message stating that "404 No matching rule has been found in the dial plan for the called number."
better to check Skype Side for this as when sending the 4 digit number 2576 To 10.106.5.58 you are getting the message.
07-01-2018 07:23 AM
I did not got your point, by the way skype is having the complete number since it is an analog line so the number is 025565xxx then extension 2576
if i understand it correctly you are saying that the skype should have number 48892576 for this user...correct me if i am wrong
07-01-2018 11:34 AM
07-01-2018 12:00 PM
Yes, but skype is not having the number as 48892576 infact it is having the number in the below format
0255652xx;ext:2576
i guess it should be only 48892576
let me know if i am saying it correct
