Community Helping Community
3273
Slip Secs and Errored Secs Occuring
I have a 3745 with a lot of slip secs and error secs on the controller. I am not versed in voice yet but I can tell call quality is not great. Some users report that callers cannot hear them.
3745#sh controller T1
T1 0/1 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20071009, FPGA: 20, spm_count = 0
  Framing is SF, Line Code is AMI, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (569 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     569 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     569 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     86400 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     86400 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 4/0 is up.
  Cablelength is long 0db
  No alarms detected.
  Version info Firmware: 20071011, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
   Current port master clock:recovered from backplane
  Data in current interval (685 seconds elapsed):
Also configured on the router:
no network-clock-participate slot 2
network-clock-participate slot 4
network-clock-participate wic 2
network-clock-select 1 T1 4/0
Can someone point me in the right direction to troubleshoot?
Everyone's tags (2)
7 REPLIES 7
Hall of Fame Master
Add wic 0 to network-clock-particiapte, i.e. network-clock-participate wic 0.
Can you also provide "sh network-clocks"?
Chris
Here is the result of the sh network-clocks command:
3745#sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          T1 4/0          GOOD            T1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          T1 4/0          GOOD            T1
Can you explain what network-clock-participate wic 0 does?
Hall of Fame Master
Your controller output shows you have a T1 circuit in port 0/1 assuming this is your voice circuit you are having issues with, you want to make sure it participates in clocking as all voice circuits and DSPs need to. Clock slips/errors are caused by not having proper clocking participation as evident in your environment.
HTH, please rate all useful posts!
Chris
Highlighted
Will I need to schedule maintenance to put in these commands?
Hall of Fame Master
Depends on your change management process, but applying this command does not cause any outage.
Chris
Thanks Chris. I'll try this out and post back the results tomorrow.
I tried to insert the command:
The response from the router was:
WIC slot is empty or does not support clock participate
Which commands can I use to display all the WICs?
Content for Community-Ad
FusionCharts will render here
