Slow outgoing calls via FXO
robbie.teo
My outgoing calls takes about 20sec to get thru. May I know where the problem lies on?
You can check 'show voice dsp detail | i default'. If that spits an error message you have a file in flash changing your DSPware.
-nick
Be sure if there some overlap in your dial plan scheme!
Check here (Assumes that you're using Cisco CallManager in your scenario...) for more information:
Cisco Unified Communications SRND Based on Cisco Unified Communications Manager 5.x - Dial Plan [Cisco Unified Communications Manager (CallManager)] - Cisco Systems:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/5x/50dialpl_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1043339%27)%22%3Ehttp://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/5x/50dialpl_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1043339
HTH,
Vitor
Sorry for the lack of details....
I'm using UCM 6.1 connected via FXO
currently got only 2 ip phones DN 777 and 888
My dial pattern is 6.@ and 9.@
Is there any problem with my setup that cause the delay in dailing out?
