271
Highlighted
Participant
Small Gateway to use with UCM
I have a UCM 11.x.  I need to put a voice gateway at a small remote site with a single POTS line.
Is a 1921 the smallest option or is there anything less expensive that will provide an FXO port?
1 ACCEPTED SOLUTION
Highlighted
Just a single POTS line ?? You can look into 800 series routers -
https://www.cisco.com/c/en/us/products/routers/800-series-routers/index.html#~stickynav=1
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
2 REPLIES 2
Highlighted
Nipun Singh Raghav
Highlighted
VIP Advisor
1900 doesn't support voice gateway. As mentioned look for 800 series. This
is the minimum
Content for Community-Ad
