Hi All,
Please find the attached my project scenario. Could any one please let me whether it is possible to do or not.
The Requirements are given below according to the attchment.
Requirements:
Phone Functionality
DIAL PLAN: (8 DIGITS) XXXX YYYY , where XXXX (4 digits) Site code and YYYY (4 Digits) Specific Phone number.
PC Functionality
Thanks and regards
Jegan S
Are you a Cisco partner? You will need to engage an UC certified Cisco partner, or reputable consultant to get sure and predicatable results.
Otherwise if trying to do yourself. you risk to spend much time and make costly mistakes.
Hi Paolo
*I am not a cisco parner
I have done this design for learning purpose.
I need some configurations for the mentioned scenario. Kindly help
Dear all
I am registered cisco partner, need some help to execute this project.
Yes, it's possible.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Jegan,
This forum is not designed to help people configure thier system as you are requsting. We aree here to help people who have an idea of what they are doing and they just need help to finish it. You need to engage someone who is skilled to get this done as Paolo (+5) hass suggested.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
