ā12-11-2014 08:03 AM - edited ā03-17-2019 01:17 AM
I am unable to pair my LG Nexus 5 smartphone to my Cisco 8851 IP phone. My smartphone is in "discoverable" mode, but the 8851 never finds it when attempting to add a new bluetooth device. I can see the 8851 on my smartphone screen, but bluetooth pairing fails due a PIN mismatch every time it's attempted. Am I supposed to be doing something different on the 8851?
ā02-04-2015 09:17 AM
Make sure that when you hit the Applications button on the 8851 and go to Bluetooth settings that the option "Hands-free 2-way audio" is on.
ā02-25-2016 07:55 AM
Thank you. That was it.
ā11-24-2016 01:43 AM
i have a similar issue with 8851 BT, the smartphone is pairing fine, but the quality and hearing is disaster (8851 on 10.5 firmware only).
if i downgrade the frmware to 10.3 it working great.
any ideas?
tk
shoham
ā11-10-2015 12:57 PM
That was the same problem I was experiiencing - That was the fix..
