SMTP port change UC apps such as cucm , cuc, ccx, etc
hi,
all UC is 11.5 version but when I tried to configure SMTP on them, all shows "The SMTP service is not available".  then I found out that the customer SMTP is on port 26  (all UC app uses port 25).
is there a way to change UC apps to port 26?
thanks.
vijay
Jaime Valencia
To my knowledge, that's not configurable.
java
if this helps, please rate
Ratheesh Kumar
Hi there
I afraid you don't have an option here.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
