SNR not working when EM profile logged out
amritesh.anand
SNR configuration works perfectly fine but it is not working when the user is logged out.
I am not even sure if this is supposed to work.
Amritesh Anand
5 Replies 5
anchoudh
Level 9
Level 9
Mobile Connect (SNR) is supported with EM enabled users.  The
configuration requires that you configure an EM Device Profile for the user
with the same DN as configured on the user's Remote Destination Profile (RDP).
The EM Device Profile must be associated to the end-user under the End User
configuration page (in addition to ensuring that Mobility is enabled for the
user).  All other configuration on the RDP, the Remote Destination, and the end
user account is the same as for a user without EM.  Just don't forget to
subscribe to the EM phone service to the EM Device Profile and any desk phones
you want the user to be able to login to and remember to assign a softkey
template to the user's EM Device Profile that contains the Mobility softkey.
Hope it helps.
Anand
Hi Anand,
Thanks for the reply. My Extension Mobility and SNR both works fine. Only the SNR does not work if the Extension Mobility profile is logged out.
Amritesh Anand
Vipul Jindal
it should work!!!
thanks,
Vipul Jindal
Hi Vipul,
I agree but thats not working.
Hi Amritesh,
Did you got a work arround for this issue
