10-03-2012 01:45 PM - edited 03-16-2019 01:30 PM
I have that problem to Cisco IP Phone 7942. I want to configure SNR in Cisco Ip Phone 7942, I have a CME 9.0. When I press Mobility Softkey, the Cisco IP phone 7942 doesn't make call. what is my problem. I show a part of configuration ok. I make some probes to CIPC, that work fine. Please help me ??
CME_ #sh eph phone-load
DeviceName CurrentPhoneload PreviousPhoneload LastReset
SEPC8F9F969B579 SCCP42.9-2-1S SCCP42.9-2-1S
SEP3CCE73ADB37E SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969F326 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969C284 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F9696D82 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969ED5D SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F9697472 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F9696CBC SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969E679 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F9696C9C SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969B662 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F9688B25 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969F2FB SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969F445 SCCP42.9-2-1S SCCP42.9-2-1S
SEPC8F9F969F5AB SCCP42.9-2-1S SCCP42.9-2-1S
CME #sh telephony-service
CONFIG (Version=9.0)
Version 9.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 1xx.xxx.xx.x port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
service dss
load 7942 SCCP42.9-2-1S
max-ephones 40
max-dn 100
max-conferences 8 gain -6
dspfarm units 6
dspfarm transcode sessions 2
dspfarm 1 XCODER
dspfarm 2 CCconf
dspfarm 3
dspfarm 4
dspfarm 5
dspfarm 6
conference hardware
privacy
no privacy-on-hold
hunt-group report delay 1 hours
Number of ephone hunt-group configured: 2
hunt-group logout DND
max-redirect 20
voicemail 500
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] ES (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] ES (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
phone service videoCapability 1
phone service webAccess 0
phone service SpanToPCPort 1
phone service thumbButton PTTH6
mwi relay
moh final.wav
time-format 12
date-format dd-mm-yy
timezone 15 SA Western Standard Time
url directories http:// xxx.xxx.xx.x /localdirectory
url services http:// xxx.xxx.xx.x /voiceview
url authentication http://xxx.xxx.xx.x/voiceview/authentication/authenticate.do
transfer-pattern .T
keepalive 30 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 30
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message HIGH TECH CENTER
web admin system name xxxx password xxx
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
calling-number local
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Oct 03 2012 14:19:02
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Call List BLF is enabled
ephone-dn 8 dual-line
number 108
label 108 Erick Zabala
description Erick Zabala
name Erick Zabala
mobility
snr 418 delay 6 timeout 40 cfwd-noan 418
ephone 7
device-security-mode none
description CISCO IP PHONE ERICK
mac-address C8F9.F969.F326
ephone-template 1
type 7942
button 1:8
ephone-template 1
url-button 1 http://xxx.xxx.xxx.xxxx/localdirectory localdirectory
softkeys idle Redial Gpickup Cfwdall Mobility Pickup Dnd Login
softkeys connected Endcall Trnsfer Mobility LiveRcd Join Park Confrn
keep-conference
keepalive 200
type 7942
