ā08-09-2017 06:27 AM - edited ā03-18-2019 12:19 PM
Please I have implemented SNR in CME.
When the call ring in the mobile phone, I try to answer but I hear busy tone.
here the config:
voice register dn 1
snr 032122656 delay 0 timeout 60 cfwd-noan 150
snr calling-number local
snr ring-stop
Wht can be the issue
ā08-09-2017 08:18 AM
What type of PSTN connectivity are you using? PRI, SIP, analog? Be aware that SNR is not supported with analog ports.
Brandon
ā08-11-2017 04:16 AM
SIP trunk.
below a trace.
call from extenson 203 to 214.
214 is configured SNR 58580107.
58580107 is the mobone number
in attachement a trace
ā08-14-2017 12:50 AM
can some one update? thank you
ā08-09-2017 08:30 AM
Are you able to make a normal phone call & answer in that Mobile
I suspect a timer issue
How long the Mobile rings, can you let the Mobile ring for two or more rings and then try to answer the call
