softkey templates trouble
Hello
Im  trying to configure a softkey template, in wich  the "dial" softkey is  always show however I cant find this softkey in any layout. This softkey  is show when the phone is on-hook and at least one  digit has been dialed.
¿Does anyone know if it is possible?.
Im  want to do this because some users are complaining about the interdigit  time out when dialing two digits numbers, I already check my route  patterns in order to make them more specific, i think the problem is  that i have  XXXXX for  some numbers of the same customer. btw the there  is no chance to increase the digits of some numbers from 2 to 5. Also  the t. 302 timer is already 3 sec.
Rob Huffman
Hi Arturo,
It's not possible to manipulate the Dial Softkey in this way
Have your users tried dialing the 2-digit DN followed by # to overcome
the IDT?
Cheers!
Rob
Rob Huffman
Hi Arturo,
the IDT?
Cheers!
Rob
thanks for the info rob
About the #  I have already tried that, when # is pressed  the " your call cant be completed as dialed " record is played..
