Software IP phone
Hello friends,
i need a free software ip phone that i can register in my cisco 3945 CME. Do you have any suggestions? Thanks
PS. i need SCCP protocol ip phone
Hi.
IP communicator is SCCP.
Other softphone talking SIP protocol are configurable with CME.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
I use X-Lite time to time: http://www.counterpath.com/x-lite
Martin
x-lite is SIP based - not SCCP. SCCP is Cisco proprietary so Cisco IP communicator is definitely best option...
HTH,
Dragan
HTH,
Dragan
Yes, that's true.
Is there any special reason to have SCCP instead of SIP?
