[SOLVED] Problem with voip and pots dial-peers between two CME
felipecarneiro
Beginner
Beginner
Hello, I'm having trouble to configure a voip trunk between two routers running CME. Can anyone help me please?
I have the following scenario:
[Analog phone ext 2923]----[PBX]----(FXO)[2911 CME-B]-----[2811 CME-A]-----[VoIP phone ext 3103]
I've configured a dial-peer pots on CME-B to route calls with dest pattern 29.. to FXO port 0/1/0, which is connected to the PBX. Inside this router everything is working fine, I can call ext 2923.
I've also configured a dial-peer voip on CME-A, directing calls with pattern 29.. to CME-B (tried both SIP and Cisco protocols). Here is my problem. When I call 2923 from an IP Phone connected to CME-A, the analog phone on the other side (sometimes) rings once and the the call is disconnected, either showing "Unknown number" or just hanging up.
6 Replies 6
Tagir Temirgaliyev
Frequent Contributor
please share full config 2911 and 2811
acampbell
Advocate
Advocate
Can you confirm the configs of both the pots & voip dial peers
Something like this should work fine:-
CME-A
dial-peer voice 29 voip
 description CME-B 29.. PEER
 destination-pattern 29..
 incoming called-number .
 session target ipv4:192.168.1.254
 dtmf-relay h245-alphanumeric
 ip qos dscp ef media
 ip qos dscp cs3 sig
 no vad
CME-B
dial-peer voice 29 pots
description FXO 0/1/0 29.. PEER
forward-digits all
direct-inward-dial
port 0/1/0
dial-peer voice 3 voip
 description CME-A 3... PEER
 destination-pattern 3...
 session target ipv4:192.168.100.254
 ip qos dscp cs3 sig
 no vad
Alex
Regards, Alex. Please rate useful posts.
Nadeem Ahmed
can  you please enable below debugs and make a test call
enable this debug on CME-B r
debug voice ccapi inout
debug vpm signal
debug voice vtsp all
on CME-A
debug ccsip message
share the config from both CME's in separate file along with debugs collected
Br,
Nadeem Ahmed
PS: Please rate all useful post
Br, Nadeem Please rate all useful post.
In CME-B you are matching dial pees 2901 not 2900
What is the config of dial peer 2901
Alex
Sorry, I forgot to mention it, dial-peer 2900 and 2901 have the same configuration except the port. dial-peer 2900 is port 0/1/0 and 2901 port 0/1/1. (just corrected my previous post)
But anyway, I solved the problem by disabling supervisory disconnect anytone on both voice-ports.
felipecarneiro
Beginner
Beginner
Thanks for your reply, but still not working with acampbell's configuration.
My config is as as following:
"CME-A"
dial-peer voice 2900 voip
 session target ipv4:10.10.0.127
 no vad
"CME-B"
dial-peer voice 3100 voip
 description "Ramais VoIP GBT - 31xx"
 destination-pattern 31..
 session target ipv4:10.1.14.1
 session transport udp
 no vad
dial-peer voice 2900 pots
 description "ACC - PABX Analogico (29xx)"
 direct-inward-dial
 port 0/1/0
 forward-digits all
debug voice dialpeer output when calling from 3103 (VoIP) to 2923 (analog PBX):
"CME-A"
Feb 10 16:55:01.363: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3103, Called Number=, Voice-Interface=0x4A34ACAC,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
Feb 10 16:55:02.631: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2
   Result=Partial Matches(1) after DP_MATCH_DEST
Feb 10 16:55:02.631: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Feb 10 16:55:03.439: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=29, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=29
Feb 10 16:55:03.439: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
Feb 10 16:55:03.903: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=292, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=292
Feb 10 16:55:03.903: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
Feb 10 16:55:04.639: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2920, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2920
Feb 10 16:55:04.643: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
Feb 10 16:55:04.643: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2900
   Result=SUCCESS(0)
Feb 10 16:55:04.647: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 10 16:55:04.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2920, Called Number=2920, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 10 16:55:04.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 10 16:55:04.647: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   Calling Number=2920, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2900
   Result=SUCCESS(0)
Feb 10 16:55:04.651: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
Feb 10 16:55:04.651: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 10 16:55:07.127: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=3103, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=3103
Feb 10 16:55:07.127: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20001
Feb 10 16:55:07.131: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:07.131: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Feb 10 16:55:07.139: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:07.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:07.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Feb 10 16:55:07.243: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=29.., Called Number=, Voice-Interface=0x0,
Feb 10 16:55:07.247: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3103$, Called Number=, Voice-Interface=0x0,
"CME-B"
Feb 10 16:55:04.409: //-1/DBE9C87A8026/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3103, Called Number=2920, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3100
Feb 10 16:55:04.409: //-1/DBE9C87A8026/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Feb 10 16:55:04.409: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:04.409: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=2920, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Feb 10 16:55:04.409: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2901
Feb 10 16:55:04.413: //-1/DBE9C87A8026/DPM/dpMatchPeersCore:
Feb 10 16:55:04.413: //-1/DBE9C87A8026/DPM/dpMatchSafModulePlugin:
Feb 10 16:55:04.413: //-1/DBE9C87A8026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Feb 10 16:55:04.413: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:04.413: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 10 16:55:04.413: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 10 16:55:04.413: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Result=SUCCESS(0)
   dialstring=2920, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
Feb 10 16:55:06.817: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:06.817: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 10 16:55:06.817: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3100
   Result=SUCCESS(0)
Feb 10 16:55:06.821: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 10 16:55:06.821: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 10 16:55:06.821: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
BLM-ACC-RT27#
Recognize Your Peers
