some extensions has problems
Abood
hello
i have in Route Partition : TU_Employees_P and TU_Managers_P
i always use TU_Employees_P when i try to call extension to another extension  . i have extension were using in Route Partition tu_employees i have changed to tu_managers ... and i can get call
so what the issue .. when i use TU_Employees_P ?
so what i can do to make all route partion
Can you use http://ccum-ip/dna to trace call routing and see where its
failing
Results Summary
Calling Party Information
  • Calling Party = 6609
  • Partition = TU_Employees_P
  • Device CSS = Internal-CSS_1
  • Line CSS = TU_Managers_CSS_test
  • AAR Group Name =
  • AAR CSS =
Dialed Digits = 6753
Match Result = RouteThisPattern
Matched Pattern Information
  • Pattern = 6753
  • Time Schedule =
Called Party Number = 6753
Time Zone = Asia/Riyadh
Call Classification = OnNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern=
External Phone Number Mask = NO
Calling Party Mask =
Prefix =
CallingLineId Presentation =
CallingName Presentation =
Calling Party Number = 6609
ConnectedLineId Presentation =
ConnectedName Presentation =
Called Party Mask =
Discard Digits Instruction =
Prefix =
Called Number =
  • Partition =
  • Positional Match List = 6753
  • Calling Party Number = 6609
  • PreTransform Calling Party Number =
  • PreTransform Called Party Number =
  • Calling Party Transformations
  • ConnectedParty Transformations
  • Called Party Transformations
Directory Number :DN= 6753
Forward All : DN = VoiceMail = No CSS =
Forward Busy
  • Internal : DN = VoiceMail = No CSS =
  • External : DN = VoiceMail = No CSS =
Forward No Answer
Forward No Coverage
Forward Unregistered
CFDF : DN = VoiceMail = No CSS =
Pickup Group Number =
Device Status = Registered
Device Name = SEP3CCE73ACF798
Ignore Presentation Indicators = Disabled
Logged Into Hunt Groups = Enabled
Alerting Name = Abeer Hassan
Dual Mode = Disabled
Do Not Disturb(DND)
  • DND Status = Disabled
  • DND Option =
  • DND Incoming Call Alert =
Automated Alternate Routing (AAR)
  • AAR Group Name =
  • AAR Calling Search Space =
  • AAR VoiceMail Status = Disabled
  • AAR Destination Mask =
  • AAR Prefix Digits =
Device Name = SEP3CCE73AD0371
Do Not Disturb(DND)
  • DND Option =
  • AAR Group Name =
  • TypeCFACSSPolicy =
  • Call Classification = Unknown
  • Forwarding Information
  • Device :Type= Cisco 7965
Alternate Matches
Partition :Name= TU_Managers_P
Pattern = 6753
Pattern Type = Enterprise
CallManager Device Type = UserDevice
PatternPrecedenceLevel = PlDefault
PatternRouteClass = RouteClassDefault
  • Pattern
Partition :Name= Huawei_PT
Pattern = 6XXX
Call Classification = OffNet
CallManager Device Type = AccessDevice
  • Pattern
Partition :Name=
Pattern = 6753
  • Pattern
Jaime Valencia
Might want to read this chapter of the SRND, particularly CSS and partitions, which are basic building blocks for CUCM call routing
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/dialplan.html
java
if this helps, please rate
