some numbers are not routed
engreda22
In can't call any local number starts with 46
below the call information and attached the logging
Call Control Block (CCB) : 0x0x30E10E8
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 4552
Called Number            : 94646677
Source IP Address (Sig  ): 172.20.201.18
Destn SIP Req Addr:Port  : 10.0.32.220:5060
Destn SIP Resp Addr:Port : 10.0.32.220:54271
Destination Name         : 10.0.32.220
000643: Jul 27 16:37:55.320: //155969/AE4141000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 172.20.201.18
Source IP Port    (Media): 30136
Destn  IP Address (Media): 10.0.32.220
Destn  IP Port    (Media): 26106
Orig Destn IP Address:Port (Media): [ - ]:0
000644: Jul 27 16:37:55.320: //155969/AE4141000000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
any advice please
16 Replies 16
Dear Tagir
How to solved this issue?
TIA
Cristian
Please your configuration. I can see in your SIP INVITE towards the ITSP that your are sending payload type 19 which is reserved. This might be a problem but depends on your configuration.
