Some sort of CRA integrated in CUCM?
NatalieThomas
Our customer needs the possibility to play recordings, for example when  the line is busy or after closing hours. Is this function integrated in  CUCM9.0? I was thinking of Customer Response Application which I know  from our CallManager4.2.
Thank you very much in advance for your help.
Kindest regards,
Natalie Thomas
2 Accepted Solutions
barry
Level 7
Level 7
Hi Natalie
CRA (which later morphed into the Contact Center suite I believe) was always delivered on a separate server to CUCM.
This is still true in version 9.x and CUCM doesn't do this natively. However a much more cost effective way to do this would be to use Cisco Unity Connection voicemail. You can write your own call handlers which can be driven based on schedules.
HTH.
Barry Hesk
Intrinsic Network Solutions
Rob Huffman
Hi Natalie,
I'll just add another option to the great tips from Barry (+5 "B" )
With the release of CUCM 9.x there is native Call Queuing (with message
recordings) which might be used for your busy situations.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_0_1/ccmfeat/CUCM_BK_CEF0C471_00_cucm-features-and-services-guide_chapter_0111.html
The "co-resident" install capabilities with CRA/IPCC & CUCM was
deprecated with the release of CUCM 5.x I believe;
here's some "old" info just as an FYI;
You can install Cisco CRA 3.1 in either of these basic server configurations:
  • Dedicated installation—Install Cisco CRA alone on a server.
  • Co-resident installation—Install Cisco CallManager and Cisco CRA on the same server.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_installation_guide_chapter09186a0080193e6d.html
Cheers!
Rob
"What you don't have you don't need it now"
- U2
barry
Level 7
Level 7
Hi Natalie
HTH.
Barry Hesk
Rob Huffman
Hi Natalie,
Cheers!
Rob
- U2
Great, that was more than helpful!
Thanks a lot,
Natalie
