09-19-2011 12:33 PM - edited 03-16-2019 07:04 AM
Is there any way to configure the SPA501g on CME 7 ?
Tks
03-08-2012 12:06 PM
Hello...
You can try with this commands
voice service voip
ip address trusted list
ipv4 172.30.0.0 255.255.254.0
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 172.30.0.1 port 5060
timeouts interdigit 2
max-dn 70
max-pool 70
authenticate register
authenticate realm csb.com
tftp-path flash:
file text
create profile sync 0006058169035549
voice register dn 1
number 505050
voice register pool 1
id mac 7081.053E.227C
number 1 dn 1
template 1
dtmf-relay sip-notify
username user1 password cisco
codec g711ulaw
I configure this phone with CME 9.0 but i think it could work with 7.0 too
I hope it helps
03-08-2012 01:21 PM
SPA phones in SCCP (SCPC actually) mode are supported on the UC5x0 only.
If you can convert them to SIP you can configure as third-party, but they will work poorly and without features.
