SPAN and SIP Trunk Recording in parallel
tyroneclark871
Beginner
Beginner
I am looking at moving away from using SPAN voice recording and utilise SIP trunk automatic call recording (per UDP using a DMS pool on Verint recorder).
My question is, if I were to implement SIP trunk recording in parallel with SPAN recording, would this interfere? I need to carry out a POC of the solution but cannot interrupt the current recording.
Thanks for any help you can give me!
1 ACCEPTED SOLUTION
m.batts
Enthusiast
Enthusiast
With traditional SPAN port recording the Callmanager is unaware the phone is being recorded , so when you turn on active recording there shouldn't be any impact.
However you may end up with duplicate streams at the voice recording end , so not sure what verint would make of that .
2 REPLIES 2
m.batts
Enthusiast
Enthusiast
Thanks!!
