Spark-Registered In-Room Control on CE Software Getting "User not authorized"
I am getting "User not authorized" when trying to issue this command on an MX300-G2 registered to Spark:
xCommand HttpFeedback register FeedbackSlot: 1 ServerUrl: "http://192.168.21.129:5000/codec" Expression: "/event/UserInterface/Extensions/Widget"
*r HttpFeedbackRegisterResult (status=Error):
*r HttpFeedbackRegisterResult Reason: "User not authorized"
*r HttpFeedbackRegisterResult XPath: "/HttpFeedback/register"
** end
I logged in with both a "room control" user, and an "integrator" user.  Neither works.  The fact that you can create the accounts would indicate this is supported.  Am I missing something?
Thanks.
Sal
5 Replies 5
Justin Ferello
Contributor
Contributor
Salvatore,
xCommand HttpFeedBack is not supported on Cisco Spark registered endpoints.
See the section "Limitations" in the link below:
https://collaborationhelp.cisco.com/article/en-us/n5pqqcm
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
So the obvious next question is - when will this be supported?  Is there any way to use In-Room Controls on a Spark Registered endpoint?   Is this coming?
Sal,
That I am not sure of.  However, In-Room Controls work for the most part.
Justin
Thank you,
Justin Ferello
I'm almost there.  I registered my peripheral (web server) like so:
xcommand Peripherals Connect ID: "503f5601da14" NetworkAddress: "http://172.16.5.65/codec" Type: Other
And then I registered my Events:
xfeedback register event/UserInterface/Extensions/Widget
and I get this which is great:
*e UserInterface Extensions Widget Action WidgetId: "widget_2"
*e UserInterface Extensions Widget Action Value: ""
*e UserInterface Extensions Widget Action Type: "pressed"
** end
*e UserInterface Extensions Widget Action Type: "released"
** end
I'm just not getting anything on my web server.  What's the missing link?  There's got to be a way to tell the system to send the out of the widget interactions to my Web server.  I'm almost there, but I can't seem to get it.
Sal
mmihalyf
Looks like the issue is over:
https://collaborationhelp.cisco.com/article/en-us/n4lhv2s
"Increase in Administrator and API Access
You can now create an Admin user from the devices Advanced Settings."
Recognize Your Peers
