01-29-2015 11:06 AM - edited 03-17-2019 01:46 AM
I have a speed dial to configure like below.
If they dial 123 it will ring 00123456789 number in PSTN and there is a route pattern created for
00[1-8]XXXXXXXX
Hence I have created a route pattern 123 with called party transformation as 00123456789 but whenever we are dialling 123 the call is not going out to GW.
In CDR it looks like it is not loading the partition for the called Party number.
Any ideas?
01-29-2015 11:27 AM
I'd start by simply checking all the CSS and partitions of all elements involved, if the call is not making it to the GW, then the issue is clearly in CUCM.
01-29-2015 12:19 PM
Hi Jaime,
I checked that the partition that I put on this route pattern is already included on calling search space from which extension is being called.
What other option do I have to set it up in GW?
01-29-2015 02:03 PM
You have to to nothing on the GW, if you dial that 001 whatever number from an IP phone, does it work??
If it does, then you somehow misconfigured the TP.
01-30-2015 04:04 PM
Used DNA and found that I created a TP with that number which should have been deleted before to the newly created RP to work. Hence deleted the TP and it started working.
01-29-2015 11:49 AM
Try running Dynamic Number Analyzer
https://<cucm>/dna
You may have to activate the service first.
