03-17-2016 03:47 AM - edited 03-17-2019 06:17 AM
I have CME ver 10.0 and some phones sccp and sip , i configured speed dial on phone 7821 and when i press 1 then speed dial nothing happened why ?
tftp-server flash0:kern2.78xx.11-0-1-11.sbn
tftp-server flash0:kern78xx.11-0-1-11.sbn
tftp-server flash0:rootfs2.78xx.11-0-1-11.sbn
tftp-server flash0:rootfs78xx.11-0-1-11.sbn
tftp-server flash0:sboot2.78xx.11-0-1-11.sbn
tftp-server flash0:sboot78xx.11-0-1-11.sbn
tftp-server flash0:sip78xx.11-0-1-11.loads
voice register pool 2
busy-trigger-per-button 2
id mac C472.95A9.985E
type 7821
number 1 dn 2
dtmf-relay rtp-nte sip-kpml
username 2 password 1111
description IT Support 1
codec g711ulaw
no vad
speed-dial 1 2244 label "IT 2"
speed-dial 2 2345 label "M.R"
speed-dial 3 2010 label "Am Ahmed"
speed-dial 4 3004 label "Sherif Ahmed"
speed-dial 5 3003 label "Essam"
03-17-2016 06:14 PM
Did you try dialing the extension 2244 manually? Do you get any fast busy or other error when you try to use the speed dial 1? Do the other speed dials work?
Lastly can you capture the output of debug ccsip messages while you make a call and post here?
-Terry
Please rate all helpful posts
03-20-2016 03:53 AM
Hi [@Terry.Cheema] ,
I can reach to extension 2244 manually , i didn't get any fast busy or other error , the other speed dials didn't work . why
and not output of debug ccsip messages while i make a speed dial.
