Speed Dial Migration
stharmal
Hi ,
   We are running  CUCM 7.1 and planning to migrate all the users to a different cluster. The new cluster is also CUCM 7.1 but not exact version.
IS there anyway we can migrate the speed dials ?
Phones are running SCCP.
Siva
jehlas
Hello Siva,
I did a little testing and unless you plan on keeping the same IP Phone as the user is currently using I do not see a way to do this.
If they are keeping the same IP Phone, you can try a Bulk Admin Export and then Import into the new system but you will have to make some modifications to the .txt/.xls that is generated to match device pool settings etc of the new cluster.
Hope this helps,
John
