12-12-2012 11:50 AM - edited 03-16-2019 02:41 PM
Hi All ,
i have configured cisco 9971 video ip phones on CUCM 8.
i have cofigured 7 speedials but i can see on 5 speed dials on ip phone .
i can that on callmanager 2 speed dials are located under "Add on Momodule " option.
kindly advise what changes can bring all 7 speed dials on ip phone's display .
regards
12-12-2012 12:10 PM
The 9971 has up to 6 buttons natively. You can add an expansion module to increase that total.
12-12-2012 12:57 PM
this is the module you would need for 9971:
however you can use the unassigned speed dials as "abbreviated dials" if that works for you. You can search end user documentation on abbreviated dialing (speed dialing).
HTH,
Chris
01-03-2013 05:29 AM
HI,
I am also facing the same issue. I configured 7 buttons for BLF speed dial but i can see 5 on 9971 and 4 on 9951. There are 10 buttons physically available on the phone but in CME 8.8 i can see maximum of 7.
Anyone knows whats the issue.
Many Thanks
01-03-2013 06:52 AM
This is not an issue as the buttons on the left are session buttons and cannot be programmed. So it works as designed.
Chris
