124
Beginner
Speed dials
Hi all
Hope you may help. My search has yet to uncover the answer.
I have a 78xx phone  2 lines reprogrammed , cucm 10.x and would like to have a number of speed dials available (more than 30). The speed dials are added via the self servive portal. When i scoll on the phone using the circle navigator. Only the first 6 show.  Any ideas on how to fix this so we have all speed dials available
4 REPLIES 4
Enthusiast
Re: Speed dials
Please confirm what is the configuration of phone button template assigned to that phone.
Beginner
Re: Speed dials
Hi Piyush
Thanks for your reply. I'll check this and get back to you. Is the phone button template where we would set the amount of speed dials which can be accessed?
Hall of Fame Cisco Employee
Re: Speed dials
That is by design, you don't see all the speed dials you have configured, only a limited number, and if I recall correctly, that might change depending the phone model, you would need to use the remaining speed dials as abbreviated dials.
java
if this helps, please rate
Beginner
Re: Speed dials
Thank you for the clarity.
Content for Community-Ad
August's Community Spotlight Awards
