Speeddial pause
balitewiczp
Level 2
Level 2
Is there a way to insert a pause within a speedial number.  I thought it was a  comma, but cant really remember.
thanks
Jaime Valencia
Assuming you're asking on CUCM, no, there's no way to do that.
The , means a 1 second pause but that's on Unity/CUC
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
yep, its exactly what I needed.  many thanks
paolo bevilacqua
You can use my "speed dial with pauses" TCL/IVR script for the purpose. It requires H.323 on the router.
www.ciscoscripts.com
