SQL Query for AAR Destination Mask
bbenner
Beginner
Beginner
CUCM 8.0(3)
Does anyone have an SQL query string to retrieve the AAR Destination Mask of each DN?
Beau
Robert Thomas
Rising star
Rising star
I build the following query for my lab server version 7.1.5. Notice the syntax might change for newer versions
admin:run sql select aardestinationmask, dnorpattern, fkroutepartition,  aardestinationmask from numplan
aardestinationmask dnorpattern fkroutepartition                     aardestinationmask
NULL               7012        NULL                                 NULL
                    7012        84add69b-39d7-5886-a3e9-d66c5978fade
NULL               7013        NULL                                 NULL
NULL               207         84add69b-39d7-5886-a3e9-d66c5978fade NULL
NULL               7014        NULL                                 NULL
                    7015        NULL
                    7016        84add69b-39d7-5886-a3e9-d66c5978fade
                    4000        NULL
                    7017        NULL
                    4001        84add69b-39d7-5886-a3e9-d66c5978fade
                    5000        NULL
                    7017        84add69b-39d7-5886-a3e9-d66c5978fade
NULL               100         NULL                                 NULL
                    Line        NULL
                    Line2       NULL
NULL               XXXXXXXXX   50272a35-a2cc-2f0b-ac4e-1691aadee6e0 NULL
NULL               9!          NULL                                 NULL
                    1           NULL
                    7777        NULL
NULL               100         50272a35-a2cc-2f0b-ac4e-1691aadee6e0 NULL
NULL               40          NULL                                 NULL
NULL               7018        NULL                                 NULL
NULL               10XX        84add69b-39d7-5886-a3e9-d66c5978fade NULL
                    30001       NULL
                    7010        84add69b-39d7-5886-a3e9-d66c5978fade
                   7011        84add69b-39d7-5886-a3e9-d66c5978fade
I've tweaked that query a little bit.
Now you will also get the partition in which the DN belongs, also it will only show actual DNs.
Please modify the query on the end. Where I've put the 99% you just enter the beginning of your DNs. The % have to stay there because it's a wildcard. If you would like to see all Numbers including all routepattern, just cut of the end "where ndnorpattern like '99%'"
The tweaked query is
run sql n.aardestinationmask, n.dnorpattern, r.name from numplan as n full join routepartition as r on r.pkid = n.fkroutepartition where n.dnorpattern like '99%'
I've tested this on CUCM 8.6.2
Recognize Your Peers
