SQL request for Cisco Callmanager 11.5 which gives result with next rows Device Name, Description, Device Type, Device Protocol, Statusand IPv4 Address
softserveinc
I need sql request for Cisco Callmanager 11.5 which gives result with next rows Device Name, Description, Device Type, Device Protocol, Statusand IPv4 Address similar like Device -> Phone on Callmanager's web page.
Maybe somebody has the same task and help me with it?
Thank you in advance.
Rajan
YOu could try "show risdb query phone" and save the output as a csv file.
Rajan
Rajan,
I need to do sql request via axl.
For example
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
<soapenv:Header/>
<soapenv:Body>
<ns:executeSQLQuery sequence="?">
<sql>select * from device</sql>
</ns:executeSQLQuery>
</soapenv:Body>
</soapenv:Envelope>`
Thank you.
