SRST 911 router question
hutto.txed.net
I have some cisco 2800 routers, H.323 gateways, that I am using as SRST, I am also using them to dial 911 with an external analog direct line from the phone co.  Since this is an external line and not part of my PRI, All of my phones are IPPhones, when ever someone dials 911 it goes out the analog phone line 555-555-5555, which is plugged directly into my fxo port, which works great.  The issue is when 911 operator calls back to see if it is an emergency, there is no one to answer this line, just the router, is there a way to have this line forwarded to a ip phone, with a real person?  The reason we use the analog line, is because the phone co. can attach a real address to this number and the emergency people show up at the correct location.
Maximo,
Are you still unable to receive calls on 1114 from incoming calls through the fxo ports? If so, try configuring the plar without opx.
connection plar 1114
Yosh
HTH Regards, Yosh
10 Replies 10
yahsiel2004
Level 7
Level 7
You can create a translation rule to change the called number to the phone number of an operator or secretary or a designated person who will answer the call.
Yosh
HTH Regards, Yosh
Hi Maximo.
On the voice-port configuration you can add this command:
connection plar-opx xxxx where xxxx is the extension you want to send the call to.
Hope this helps
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo,
Great info (+5)
Yosh
HTH Regards, Yosh
I tried the command and when I call the analog line it just rings and rings.  The extension I added is my phone extension at my desk and it never rings, I tried it with just the four digit numbers and than the 7 digit with a 9 to get out, makes no difference.  Here is my router run config.
Current configuration : 2888 bytes
! Last configuration change at 12:50:56 CDT Wed Apr 3 2013 by maximo.rivera
version 12.4
hostname CCES.SRST
boot-start-marker
boot-end-marker
enable secret 5 $1$6Gm1$6PRGGqHn.G85/tNP1qS231
aaa new-model
aaa authentication login default group radius local
aaa authentication enable default group radius enable
aaa authorization console
aaa authorization exec default group radius local
aaa accounting suppress null-username
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
ip cef
ip domain name hutto.txed.net
trunk group  POTS
max-calls any 2
hunt-scheme sequential
voice-card 0
username calence privilege 15 secret 5 $1$wr8V$VpxOpiBpheZkuIm6Ikao00
username admin privilege 15 secret 5 $1$3M6e$gy56MUA/nrP8zPRkb4jDG1
interface FastEthernet0/0
ip address 10.120.100.2 255.255.254.0
duplex auto
speed auto
h323-gateway voip interface
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0
no ip address
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.120.100.1
no ip http server
no ip http secure-server
snmp-server community R1v3rH0rs3 RW
snmp-server community H1PP0$ RO
snmp-server contact Hutto ISD Technology
radius-server host 10.200.55.32 auth-port 1645 acct-port 1646 key Hutt0!sD
radius-server host 10.55.55.10 auth-port 1645 acct-port 1646 key Hutt0!sD
control-plane
voice-port 0/1/0
trunk-group POTS 1
connection plar opx 97595493
description POTS line
voice-port 0/1/1
trunk-group POTS 5
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 911 pots
trunkgroup POTS
description *** Outbound 911 ***
destination-pattern 911
forward-digits 3
dial-peer voice 9911 pots
trunkgroup POTS
destination-pattern 9911
forward-digits 3
dial-peer voice 100 pots
trunkgroup POTS
description *** Outbound local ***
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 50 voip
destination-pattern [1-8]...
session target ipv4:10.55.100.5
incoming called-number .T
dial-peer voice 51 voip
preference 2
session target ipv4:10.200.100.5
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.120.100.2 port 2000
max-ephones 25
max-dn 50
system message primary SRST - Fallback
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
scheduler allocate 20000 1000
ntp clock-period 17177904
ntp server 10.55.1.1
ntp server 10.200.1.1
end
Maximo,
You have to use 4 digits to match your dial-peers that point to cucm. Try this "connection plar opx 5493"
Yosh
HTH Regards, Yosh
Hi Maximo.
Can you activate a debug voip dialpeer inout and try to call 555-555-5555 send send us the output?
Thanks.
Carli
I ran the debug command and I get no out put to the screen, it does come back and says debugging is on.
Maximo,
enter in configuration mode and give logging monitor debug command
than exit and give a rer mon.
make again the call ang you'll see the output.
Carlo
Here it is. I set the connection plar opx 1114
Apr  3 22:01:20.384: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x6467FF84,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Apr  3 22:01:20.392: //-1/D9D095E28068/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1114, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1114
   Result=Success(0) after DP_MATCH_DEST
Apr  3 22:01:20.396: //-1/D9D095E28068/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=50
     2: Dial-peer Tag=51
Maximo,
Yosh
HTH Regards, Yosh
