SRST ATA 187
Issa NDIAYE
Hello
My ATA 187 does not register on voicegateway on SRST mode, we get a busy tone.
All other phone 6921 and 7942 register correctly.
can you help please.
call-manager-fallback
 max-conferences 2 gain -6
 transfer-system full-consult
 timeouts interdigit 3
 timeouts ringing 90
 ip source-address 10.25.X.X port 2000
 max-ephones 150
 max-dn 200 dual-line
 system message primary "YEK"
 transfer-pattern .T
call-forward pattern .T
 multicast moh 239.1.1.1 port 16384 route 10.25.X.X
 time-zone 22
 time-format 24
 date-format dd-mm-yy
thank you
Charles Hill
Take a look at bug
CSCud74510
Symptom:
No REGISTER message from non secure ATA 187
Conditions:
Non secure ATA187 and Secure SRST checked in CCM SRST configuration
Workaround:
Unmark the check box for Secure SRST in CCM.
Hope this helps.
Please rate helpful posts.
Thanks.
Hello CHARLES
I don't use secure SRST. please find voicegateway config
Thank you
