SRST configuration Voice gateway Site
TrickTrick
Level 3
Level 3
Hello everyone,
I'm overwhelmed with the huge amount of information I find when looking for SRST configuration, and Idk at this point what is appropriate in my case
All i want is to register SIP phones when the WAN link is down, and keep the same IP addresses they already have
All need is the following configuration based on This CiscoPress blog
CUCME-Router(config)# voice register global
CUCME-Router(config-register-global)# mode srst
CUCME-Router(config-register-global)# source-address X.X.X.X port 5060
CUCME-Router(config-register-global)# max-dn 40
CUCME-Router(config-register-global)# max-pool 10
CUCME-Router(config- register-global)# system message SRST Mode
When looking at other articles, I see pools configured under voice register pool with a couple of commands and a lot of other configuration parts : example mentioned in This Article
I need to know if the ciscopress config is enough or should I really add all the commands indicated in the second article
Thank you very much
bsrohan
You can define 1 voice register pool configuration block using "id network <address> mask <mask>" for all the phones to register using the phone's same IP address.
You can follow the configurations mentioned in the article.
Hope this helps !
-Rohan
Jaime Valencia
The SRST configuration guide on cisco.com has a chapter which is specific for SIP SRST, have you followed that?
java
if this helps, please rate
For now i'm just gathering information, I know that it would be easier if was trying that using real equipement now, but unfortunately I have to do that in a new incoming project, that's why i'm looking for a complete configuration so I can be well prepared
