02-08-2015 11:37 PM - edited 03-17-2019 01:53 AM
Hi we have CUCM 8.6 cluster and branch router 2811 and branch phones registered with call manager at head office.
branch router using analog lines to PSTN. i want to configure srst for the branch.
we have 6921 and 8941 model phones, where 6921 are using SCCP and 8941 using SIP.
i am not able to check SRST version on gateway.
i configured call-manager-fallback option, but i am not able to see the standby option on the phones
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.21.5 port 2000
max-ephones 40
max-dn 40
system message primary SRST Mode active
system message secondary SRST Mode Active
default-destination 2022
time-zone 31
date-format dd-mm-yy
dial-peer voice 1230 voip
description "SRST-PSTN"
preference 5
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.21.5
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
please can anyone guide me
02-09-2015 12:31 AM
if the srst reference ip address not showing up, this means either the configuration files are not updated or phones are not loaded the files. Can you try restarting the tftp service, then get the configuration file as below:
- Open CMD
- tftp x.x.x.x get SEP(MAC_Address).cnf.xml
Thank you,
Shadi
02-09-2015 03:03 AM
Might have to check SRST version, think it needs CME 8 or higher
02-09-2015 06:15 AM
Just SCCP Phones or Both phones?
