10-03-2017 03:14 PM - edited 03-17-2019 11:17 AM
Hi All,
My SRST phones are working fine. Only the issue is that customer wants the internal dialling (5 digit dialling) to be working when dialling from other sites to the SRST site. Also customer needs the 5 digit dialling for the SRST site for oubound calls to other sites to work.
Thanks!!
Solved! Go to Solution.
10-03-2017 03:56 PM
If you're asking how to translate 5 digit dialing into a number you can send over the PSTN to keep dialing habits for users, the call handling chapter of the SRST configuration guide covers this.
10-03-2017 03:56 PM
10-03-2017 04:06 PM
Hi Jaime,
Thanks for your response, I wanted to confirm other site users not in SRST how their calls will be routed to users in SRST while dialling five digits. If we put in CFUR the complete number for that unregistered phone, how that will be routed.
10-03-2017 08:49 PM
Hi There,
I would recommend you read William Bell's article on CFUR and SRST mode.
It goes over the use case you are trying to solve.
https://www.netcraftsmen.com/using-call-forwarding-unregistered-cfur-to-support-srst-mode-in-cucm/
Have a read and let us know if you still have questions afterwards.
10-03-2017 09:23 PM
