SRST IP Phone registration issue
fuhrersk8
Level 3
Level 3
                   Hello guys!
Currently I'm configuring SRST on a Cisco 2921 in conjunction with a CUCM8.6 (BE6000). When testing SRST, the phones show "MODE SRST", some pick up dial tone, some not, and on phones with dialtone phone calls did not progress. On the Cisco 2921 the debug ccapi all did not show nothing when attempting calls during the SRST test. It appears to me like phones were unable to register with the Voice Gateway (Cisco 2921). Below is the partial SRST config of Voice Gateway. My questions are the following:
1. Does it is neccesary to configure manually the ephones and directory numbers in the Cisco 2921 or phones will be allocated by the router automatically?
2. How to determine the SRST versipon currently running on Cisco 2921? Phones are 7940, 7960 and 7912.
3. On dialpeers (both voip and pots) it is necesary to enable the service mgcpapp in order to permit SRST calls to flow through the dialpeer?
4. Please reviw the SRST config below and if I'm missing something let me know!
Thanks in advanced guys, appreciate your help.
Partial SRST configuration:
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.200.54.3
ccm-manager config
mgcp
mgcp call-agent 10.200.54.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp af31 media
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.54
mgcp bind media source-interface GigabitEthernet0/0.54
mgcp profile default
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.200.54.1 port 2000
max-ephones 25
max-dn 25
system message primary Operating in mode SRST
keepalive 10
default-destination 4123
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.200.54.3 10.32.84.54
Nephtali,
The order it appears in the router config is important.  MGCP dial-peers must be first and your SRST dial-peers must come after.
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 20 pots
description Outbound Calls in MHQ
destination-pattern 9T
port 0/0/0
Please help us make the communities better.  Rate helpful posts!
31 Replies 31
Chris Deren
What is the IOS version?
What type of phones are these? Are these SCCP or SIP phones?
How many phones are you expcting to register, you are set for only 25 max phones?
What are the phones showing on the display, are they showing the extension?
Are calls working for any phones? Outbound? Inbound?
Is SRST reference configured in CUCM?
Chris
Hello Chris and thanks for your reply!
     Answers are as follows:
What is the IOS version? --> Version 15.1(4)M5
What type of phones are these? Are these SCCP or SIP phones? --> SCCP
How many phones are you expcting to register, you are set for only 25 max phones? --> less than 25
What are the phones showing on the display, are they showing the extension? --> Operating in SRST Mode and yes the extensions are showing.
Are calls working for any phones? Outbound? Inbound? --> Yes, calls are working internally. What is not working is calls from and to PSTN. After pressing 9 for outbound calls, after pressing the next digit I get busy tone. Calls inbound not working. Inbound calls should get to AA.
Is SRST reference configured in CUCM? --> Yes and included in the IP Phones Device Pool
Chris, I guess is now more an issue of matching dialpeers and routing of calls. What should I be looking for in terms of debbuging in Voice Gateway?
Thanks again!
So, looks like you have MGCP? Do you have proper dial-peers for H323 when the GW falls into SRST?  Remmeber MGCP does not work with SRST and you need proper dial peers. Also, if this is a PRI circuit you need MGCP fallback configured.
HTH,
Chris
Yes, MGCP is configured. I have both, a SIP trunk to Service Provider as the main circuit to PSTN and a FXO port as backup (mgcp gateway).
My goal is that if CUCM goes down, SRST phones still be able to route calls to and from PSTN through SIP trunk. Is this possible?
Nephtali,
Yes. It is possible.
To route through the SIP Provider either in normal or SRST mode on your IOS 15.1 router be sure to add their session border controller (SBC) to your permitted list under "voice service voip" http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml You'll also need to enable CUBE.
As Chris mentioned, be sure you've configured your dial-peers to use either the SIP trunk or the POTS lines.
To answer your questions above:
1. The ephone and ephone-dn will be created automatically
2. If you are running 7940, 7942, and 7912 phones you should be just fine on IOS 15.1
3. You do not need to use the service mgcpapp.  Call Manager will create a special dial-peers for FXO/FXS lines that use that command during MGCP configuration and you should not mess with them.  PRI-ISDN lines do not require it.  Also, for best results, ensure that any dial-peer's you create come *after* those that MGCP creates.
4. Post a more complete config and we can continue to nit-pick it for you.
-Steven
Thanks for the reply Steven. Excellent explanation. In my case, phones are registering into the router when in SRST mode and calls are proceeding between those internal extensions. The problem lies for inbound and outbound calls. I get busy tone after pressing the second digit after the 9 for outbound calls. I think is a dialpeer issue.
Below is the dialpeer created automatically by the router for mgcp:
service mgcpapp
port 0/0/0
I've created the following dialpeer for outbound calls when in SRST mode; is it necessary?
service mgcpapp
port 0/0/0
I will only use the FXO port (voice-port 0/0/0) when in SRST. In terms of dialpeers, does any other dialpeer is necessary for SRST to route calls in this scenario?
Thanks again for your support!
Nephtali,
Can you configure another pots dial peer without the service mgcp command and check. Probably you can give it a lower preference. Also when u do a show voice port sum..do u see the voice port to be up.
AJ
Nephtali,
You don't need the service mgcpapp in your dial-peer 20.  You do need 'dial-peer voice 20 pots' for SRST to work.   The important bit is that dial-peer 999000 must exist before dial-peer voice 20 in the configuration.
-Steven
Great Steven. Can I delete then dial-peer voice 20 and SRST should route both inbound and outbound calls with only dial-peer voice 999000 pots?
Thanks again!
No, you need both.  Just remove "service mgcpapp" from dial-peer voice 20.
My bad. I misread your last post. I will remove service mgcapp from dial-peer voice 20 and then will proceed to shutdown CUCM for SRST testing. One more question before proceeding, when you remark that "dial-peer 999000
must exist before dial-peer voice 20 in the configuration", you mean that it must be the first match in the process of dialpeer matching,.i.e, the most specific?
Nephtali,
service mgcpapp
port 0/0/0
port 0/0/0
Good to know. Thanks again. Any debug commands you recommend while testing?
You can do a debug voice dialpeer to check which dial peer the call matches
debug voice ccapi inout will show u the call details
AJ
