SRST License for Voice Gateway
May Simpson
Hi Xperts,
Could anyone please confirm if my understanding is correct?
We purchased C2921-CME-SRST/K9 with 25 licenses for SRST for our client.
The following is result of issuing command "show license detail cme-srst".
tokyo_gwvoice#show license detail cme-srst
Feature: cme-srst                        Period left: 7  weeks 4  days
Index: 1        Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 7  weeks 4  days
            Period used: 6  days 20 hours
            Transition date: Mar 26 2016 14:52:01
        License Count: 25/0  (In-use/Violation)
        License Priority: Low
        Store Index: 7
        Store Name: Built-In License Storage
So after 60 days this "EvalRightToUse" will change into "RightToUse" automatically?
We don't need to do anything in order to activate this SRST function for this router?
IOS version is c2900-universalk9-mz.SPA.153-3.M6.bin.
Rajan
Hi Mayumi,
Your understanding is correct. On Mar 26 2016 14:52:01, your evaluation licenses will expire and then the actual license which you accepted will come into effect. You dont need to do anything else.
Rajan
Rajan
Hi Mayumi,
Rajan
As Rajan said,Here is an excellent thread about it
https://supportforums.cisco.com/document/111386/understanding-cme-srst-license-activation
We installed few of them lately and earlier ones are all ok now.I've attached an snapshot from one of the recent ones for you as well..
***Please rate all the useful posts***
-Prabath
Hi preranda78-san,
Thank you so much for your comment, helpful link and the attached.
Relieved to know this. Thank you so much for your help!
Thanks and regards,
Mayumi
Hi Rajan,
Thank you so much for your comment.
Relieved to know about that.
Thanks and regards,
Mayumi
