SRST License on 2911
keanej
Level 3
Level 3
Guys,
I purchased a 2911 with SRST and UC licenses. I notice that the UC license is fine - but the SRST license is in 'evalrighttouse' mode. The box came with two white cardboard envelopes - one contained a SRST site license and the other a 25 seat SRST license - but they just had the product code - and no PAK numbers on the paper.
Has anyone installed SRST licenses on a 2911 ?? Do I need to ? Here is the License status at the moment.
Index: 5        Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 7  weeks 4  days
            Period used: 6  days 20 hours
            Transition date: Nov 22 2013 13:49:51
        License Count: 10/0  (In-use/Violation)
        License Priority: Low
        Store Index: 7
        Store Name: Built-In License Storage
Index: 11       Feature: uck9                              Version: 1.0
        License Type: Permanent
        License Count: Non-Counted
        License Priority: Medium
        Store Index: 1
        Store Name: Primary License Storage
Any Help appreciated
James
2 Accepted Solutions
Rejohn Cuares
Level 4
Level 4
The ISR-G2 comes with a 60-day evaluation license. After 60 days, the license changes to ?right to use?.
The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Prerequisites
? UCK9 license
? ISR-G2 already accepts UC CLIs
SUMMARY STEPS
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
DETAILED STEPS
Command or Action Purpose
Step 1 show license detail cme-srst
Example:
Router# show license detail cme-srst
Displays the available cme-srst license. EULA should be in NOT
ACCEPTED state.
Step 2 configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3 license accept end user agreement
Example:
Router(config)# license accept end user
agreement
Configures a one-time acceptance of the EULA for cme-srst
license.
Accepts EULA by typing YES.
Step 4 exit
Example:
Router(config)# exit
Exits global configuration mode.
Step 5 show license detail cme-srst
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Saves configuration.
Command or Action
Please rate replies and mark question as "answered" if applicable.
Aman Soi
Hi James,
you can refer the link for detail.
https://supportforums.cisco.com/docs/DOC-26706
regds,
aman
Rejohn Cuares
Level 4
Level 4
Prerequisites
? UCK9 license
SUMMARY STEPS
4. exit
6. write mem
DETAILED STEPS
Example:
ACCEPTED state.
Example:
Example:
agreement
license.
Step 4 exit
Example:
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Command or Action
I believe I have already completed these steps
license boot module c2900 technology-package uck9
and I also see
on my configuration.
But I notice you say  -
So I take it I dont have anything to worry about we have paid for a 25 seat license. I was worried that after the 60 days the license would appear as 'violated' but from what you are saying - I take it -   this is not the case.
Thanks for your help
James
Hi James,
U can refer the link on Paul discussion.
https://supportforums.cisco.com/thread/2075698
regds,
aman
Aman Soi
Hi James,
regds,
aman
