02-04-2008 02:20 AM - edited 03-15-2019 08:35 AM
when phones registers with SRST on gateway , appear dial-peers like 1001$,1002$,1003$ . Phones can call internal numbers, but they don't see PRI
Here is the dial-peer:
dial-peer voice 4 pots
tone ringback alert-no-PI
destination-pattern [234].....
no digit-strip
direct-inward-dial
port 0/0/0:15
02-04-2008 05:54 AM
this rule would only work for first 10 numbers 422860 - 422869, so you might to add other sub rules under voice translation-rule 111 , for example :
rule 1 /^42286/ /100/
rule 2 /^42287/ /101/
rule 3 /^42288/ /102/
rule 4 /^42289/ /103/
02-04-2008 05:50 AM
Didn't help,
Feb 4 13:49:03.947: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0061
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Called Party Number i = 0x81, '422864'
Plan:ISDN, Type:Unknown
Feb 4 13:49:03.955: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8061
Cause i = 0x809B - Destination out of order
Feb 4 13:49:13.503: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0062
Sending Complete
Standard = CCITT
Feb 4 13:49:13.515: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8062
02-04-2008 05:57 AM
You ALSO should know that outgoing calls don't see D channel
and look for this,
80 pots up up 0 down 0/0/0:15
3 pots up up 0[1234] 0 up 0/0/0:15
4 pots up up [234]..... 0 up 0/0/0:15
is it right, that this dial-peer is down?
command no shut didn't help
02-04-2008 04:42 AM
is this a local number? if so why are you matching 6 digits instead of 7 I would say you need another . in you destination pattern, correct me if im wrong
02-04-2008 08:21 AM
Maybe this help you:
3825#sh ccm-manager fallback-mgcp
Current active Call Manager: 10.10.0.1
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 17:56:05 UA Feb 4 2008
Last MGCP Fallback end time: 17:59:11 UA Feb 4 2008
I test SRST function with this
access-list 111 deny tcp 10.11.0.1 0.0.0.255 host 10.10.0.1 eq 2000
access-list 111 deny tcp 10.11.0.1 0.0.0.255 host 10.10.0.2 eq 2000
access-list 111 permit ip any any
int GigabitEthernet0/1.10
no ip access-group 111 in
02-04-2008 01:52 PM
I know you suggested this particular access list in this earlier post to Netpro -
However, you have completely forgotten that MGCP uses a combination of traffic on UDP port 2427 (for registration and voice port control) and TCP 2428 for the TCP backhaul. The access list above will only block SCCP traffic from the phones, so the phones will go into SRST mode, but your gateway will still be registered to the call manager, which is why this is not working.
So you have two options.
1) Create an new access list to block outwards traffic on UDP port 2427 and TCP port 2428 and apply this on your WAN port in the outwards direction, alongside the other access list that you have applied in the inwards directions to block the SCCP responses.
2) or simply add these IP route statements so ALL traffic to the CCM is blocked and after a short period the CCM will not send any Keepalive repsonses -
ip route 10.10.0.1 255.255.255.255 null 0
ip route 10.10.0.2 255.255.255.255 null 0
02-05-2008 12:16 AM
You are very helpful!Thanks!
But lets now suggest, what I should do.
(I don't to test SRST more +1 week)
I'm not strong in ACL
So, if I have network 10.111.70.1 that have phones which want to access CallManager ip address 10.10.10.1 so ?
access-list 111 deny tcp 10.111.70.0 0.0.0.255 host 10.10.10.1 eq 2000
access-list 111 deny tcp 10.111.70.0 0.0.0.255 host 10.10.10.1 eq 2428
access-list 111 deny udp 10.111.70.0 0.0.0.255 host 10.10.10.1 eq 2427
and then
02-05-2008 03:23 AM
Deny on the gateway towards the call manager. This blocks outgoing packets, including keepalive traffic, so the CCM stops responding to the devices and they will all drop into SRST and the MGCP will hand over to local call processing -
and then
interface gigabit 0/0
ip access-group 111 out
02-05-2008 04:19 AM
command "ip access-group 111 out"
doesn't help
where have I to use this ACL?
I use it on Gateway 10.111.70.1
When I used ACL with "in" in the end
phones registers on the GATEWAY 10.111.70.1
As you understand, I should simulate local failure in the range of GATEWAY, whithout touching something like CCM etc.
02-05-2008 04:47 AM
Can you draw us a simple text picture of how this system is connected ? Is your SRST router the WAN gateway router ? Or is there another router that is the main WAN connection ?
Paste the complete config of your routers here as well so we can understand exactly why this is not working. Without all the details it is too difficult to give you a solution.
02-05-2008 05:47 AM
and then
ip access-group 111 out/in
When I use ACL "ip access-group 111 in" phones register on Gateway 3825,but without FALLBACK MODE
02-05-2008 08:33 AM
so,how can I simulate SRST with ACL only
without using any ip routes?
Help me Gurus
