1124
Beginner
SRST on voice gateway
I have h323 gateway with sip configuration as given in cisco document, After failover sccp phones are registered. But sip phone cisco 8811 phones are not registered even, we didnt recieve any logs or hits on gateway.
1 ACCEPTED SOLUTION
Participant
* Add "max-dn" under voice
* Add "max-dn" and "mode esrst" to enable more features under voice register global.
* Also under voice register  pool add the following id network "id network 0.0.0.0.0  mask 0.0.0.0" for testing purpose and "codec g711ulaw" and "no vad".
* Make sure you have the SRST-Reference on the CUCM page  for SIP also on the CUCM.
mode esrst
system message Primary Link Failure
max-pool 10
max-dn 100
voice register pool 1
preference 1
proxy 192.168.x.x  voice gateway ip add
dtmf-relay rtp-nte sip-notify
-Kevin
6 REPLIES 6
Advocate
Can you post your config?
Can you post your config? Check the basics like SRST reference in CUCM and your configs.
Whats the firmware version of the phone? Make sure its supported : check here
-Terry
Please rate all helpful posts
Highlighted
Beginner
Dear Terry,
Dear Terry,
Phone version its showing 10.3.(1)
Basic configuration at CUCM alright.
Participant
Hi Dinesh,
Hi Dinesh,
Here is the link to configure SIP-SRST:
https://supportforums.cisco.com/document/12746456/how-implement-cisco-unified-sip-srst
8811 is supported on SRST version 10.5 IOS is (15.4(3)M ) and above:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs105spc.html
Cisco Unified IP Phone 8811
N/A
10.2.2
This should help.
-Kevin
Beginner
Kevin,
Kevin,
I follow the same document and configured below show run. I have sccp phone too. Pls suggest below are the config. Pls suggest
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname DXB-AWQ-VG1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
--More--   exit-address-family
card type e1 0 1
enable secret 5 $1$8x43$S0VQwIYA5cguHv8JYaksJ1
no aaa new-model
clock timezone AST 4 0
no ip domain lookup
ip domain name x.com
--More--  !
subscriber templating
isdn switch-type primary-net5
--More--  voice service voip
ip address trusted list
ipv4 192.168.48.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g722-64
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
h225 timeout tcp establish 3
--More--  !
default mode
max-pool 10
id network 192.168.x.0 mask 255.255.255.0
preference 1
voice-class codec 1
voice translation-rule 10
rule 1 /^\([0-9]\)/ /9\1/
voice translation-rule 20
rule 1 /^9/ //
voice translation-rule 30
rule 1 /^\(5...$\)/ /04406\1/
--More--  !
voice translation-profile addinPrefix
translate calling 10
voice translation-profile callingpstn
translate calling 30
translate called 20
voice-card 0/1
dsp services dspfarm
no watchdog
license udi pid ISR4321/K9 sn FDO19480FP5
username netadmin privilege 15 password 7 151C0E18052E262D26
username admin privilege 15 secret 5 $1$eItX$g4HvMfUK5oTiy0JSg2zLI0
redundancy
--More--   mode none
controller E1 0/1/0
framing no-crc4
pri-group timeslots 1-20
controller E1 0/1/1
vlan internal allocation policy ascending
--More--  !
interface GigabitEthernet0/0/0
ip address 192.168.x.x 255.255.255.0
negotiation auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.x.x
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
--More--  interface Service-Engine0/1/0
interface Serial0/1/0:15
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip default-gateway 192.168.48.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
--More--  ip route 0.0.0.0 0.0.0.0 192.168.48.1
control-plane
voice-port 0/1/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
--More--  !
call-manager-fallback
secondary-dialtone 9
max-conferences 3 gain -6
transfer-system full-consult
timeouts interdigit 5
timeouts ringing 26
ip source-address 192.168.xx port 2000 voice gasteway  IP add
max-dn 100
system message primary Link failure-Standby Mode
dial-peer voice 1000 pots
description National Calls
translation-profile outgoing callingpstn
destination-pattern 90[2-36-9][1-8]......$
progress_ind alert enable 8
dial-peer voice 1001 pots
description Mobile Calls
destination-pattern 905[0526].......$
--More--   progress_ind alert enable 8
port 0/1/0:15
dial-peer voice 1002 pots
description Emergency Calls
destination-pattern 99..$
forward-digits 3
dial-peer voice 1003 pots
description Service Calls
destination-pattern 91..$
forward-digits 3
dial-peer voice 1004 pots
destination-pattern 999
dial-peer voice 1005 pots
destination-pattern 900T
dial-peer voice 1006 pots
description Toll Free Calls
destination-pattern 9[678]00T
dial-peer voice 1007 pots
description Local Calls
destination-pattern 9[2-8]......$
dial-peer voice 1008 pots
destination-pattern 904[2-8]......$
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
--More--   port 0/1/0:15
dial-peer voice 5600 voip
translation-profile outgoing addinPrefix
preference 2
destination-pattern 57..$
session target ipv4:192.168.xx
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 5601 voip
preference 1
voice-class codec 1
voice-class h323 1
no vad
Participant
mode esrst
max-pool 10
max-dn 100
preference 1
-Kevin
Beginner
After doing this procedure
After doing this procedure different model of Phones are registered like 7821 phones. But this phones taking long time to fall-back on srst or viseversa.  Could you pls tell me exact router version support.
I am referring below link
http://docwiki.cisco.com/wiki/Cisco_Unified_SRST_Manager_Compatibility_Matrix
its says require router version should be 15.6 for cisco IP Phone 8811.
Content for Community-Ad
August's Community Spotlight Awards
