Cisco Community Designated VIP Class of 2020
639
Highlighted
Beginner
SRST: Phones not registering using VRF and MPLS
Greetings.
I have a point - to - multi point MPLS network that is using VRF groups with MPLS/EIGRP/BGB (I am not verify familiar with routing protocols).  When a phone goes into srst mode, they do not register with the local gateway.  I am able to replicate this in a lab environment.
Topology is thus:
IP Phone connected to 3750 access switch
3750 Access switch connected to 2921 ISR (datak9 (eval), uck9 (eval))  IOS is: c2900-universalk9-mz.SPA.152-4.M1.bin.
2921 connected to production 6500
6500 connected to production 2921 (WAN gateway)
Lab CUCM connected to access switch connected to 6500
ip vrf voice
rd 30:30
route-target export 30:30
route-target import 30:30
mpls label protocol ldp
voice vrf voice
voice service voip
h323
interface Loopback0
ip address 1.1.1.9 255.255.255.255
interface GigabitEthernet0/0
description WAN link to MPLS
ip address 10.253.0.254 255.255.255.0
duplex full
speed 100
mpls mtu 1508
mpls ip
no cdp enable
interface GigabitEthernet0/1
description link to site switch
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2000
description Local Voice Network 172.27.84.0
encapsulation dot1Q 2084
ip vrf forwarding voice
ip address 172.27.84.1 255.255.255.0
ip helper-address 10.10.20.15
ip helper-address 10.10.121.16
mpls ip
router eigrp 100
network 1.1.1.9 0.0.0.0
network 10.253.0.0 0.0.0.255
network 10.255.251.0 0.0.0.7
redistribute static
router bgp 100
bgp log-neighbor-changes
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 update-source Loopback0
telephony-service
group 1 vrf voice
  ip source-address 172.27.84.1 port 2000
srst mode auto-provision none
srst dn line-mode dual
max-ephones 12
max-dn 24
max-conferences 8 gain -6
transfer-system full-consult
When null0 routing to the CallManager (ip route vrf voice 10.10.20.19 255.255.255.255 null0), the device loses connectivity and begins searching.  The device never registers with the gateway, but I do get this from a 'debug ip tcp trans'
Reserved port 0 in Transport Port Agent for TCP IP type 0
TCP: connection attempt to port 2000
TCP: sending RST, seq 0, ack 2207086699
TCP: sent RST to 172.27.84.40:50594 from 172.27.84.1:2000
Released port 0 in Transport Port Agent for TCP IP type 0 delay 240000
TCP0: state was LISTEN -> CLOSED [0 -> UNKNOWN(0)]
TCB 0x31D49BD4 destroyed
TCP0: ACK timeout timer expired
I am able to ping the device from the vrf ('ping vrf voice 172.27.84.40') and from extended pings from interface g0/0 (traceroute actually sends this traffic back to the WAN router and from their back to the lab (remote) router), but not from the subinterface g0/1.2000.  From what I am attempting to understand from vrf docs is that this is normal.  I do have an SR on-going with TAC on this, but I thought I'd ping the community to see if there is any others who have seen this.
Robert.
Everyone's tags (4)
Content for Community-Ad
FusionCharts will render here
