SRST question
PijamaMan
When in SRST mode, is it possible to define witch phones do register with the SRST gateway? For example I have 60 phones in the same region, as define in the CallManager (4.2), but the license for the SRST is only to 48 phones, and I would like to be able to define witch phones continue to work until the WAN link is re-establish. Is this possible and how?
thisisshanky
Level 11
Level 11
Yes, Simply create two device pools and one SRST reference for this remote site. Assign DP1 to SRSTREF1 and DP2 - set the SRST reference to disable.
Assign the phones that require SRST to DP1 and Assign the phones that do not require SRST to DP2.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
Sankar
Sankar Nair
