Highlighted
SRST & SIP
I have a SRST router and i want to register SIP Phones (7965) on it.The matter is my SIP phones never try to register on the router (i have used Wireshark to know it, no SIP register request from phone to SRSR router)) whereas SCCP Phones in the same device pool work well.
Here is my configuration :
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
sip
  registrar server
voice register pool  1
id network 172.20.30.0 mask 255.255.0.0
preference 2
proxy 172.20.30.254
voice-class codec 1
voice register pool  2
id network 192.168.1.0 mask 255.255.255.0
proxy 172.20.30.254
voice-class codec 1
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 172.20.30.254 port 2000
max-ephones 24
max-dn 24 dual-line
SRST router ( v15.1(3) ): 172.20.30.254
Phones : 172.20.0.0/16 and 192.168.1.0/24
What is my mistake ?
Thank you for your help !
François
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
SRST & SIP
If the phone's aren't trying to register to your SRST router, it sounds like you might have missed on CUCM under the SRST reference the "SIP Network/IP Address" setting.  That's how your SIP phones know to try and register to your SRST gateway if they cannot connect to call manager.
6 REPLIES 6
Highlighted
Hall of Fame Master
SRST & SIP
Do you have registar server defined:
sip-ua
registrar ipv4:172.20.30.254 expires 600
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_setting_up_using_sip.html
HTH,
Chris
Highlighted
SRST & SIP
What do these commands do ?
The first one create a SIP user-agent on the router and the second one try to register this user-agent, right ?
What should I see after that ?
Thank you for the guide, I used it to do the configuration, but I've probably missed something...
Sorry for my poor English...
Highlighted
SRST & SIP
Do you see the IP of SRST router listed on IP Phone's web page?
Is it the same as voice register global IP?
Udit
Highlighted
SRST & SIP
No, I can't find it... In which field should it appear ?
I really don't understand why the phones doesn't even try to register on the router...
Highlighted
SRST & SIP
Highlighted
SRST & SIP
So simple... I thought SIP phones will use the same reference than SCCC Phones...
Thanks a lot ! Problem solved.
