08-31-2015 03:05 AM - edited 03-17-2019 04:09 AM
I am using CUCM 10.5.2 and need to create a SSH user using CLI. Can anybody please let me know the steps.
Thanks in advance.
Debasis
Solved! Go to Solution.
08-31-2015 04:04 AM
Hi Debasis,
You can use the "set account name" command as explained here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/10_5_2/CUCM_BK_CA8D6D40_00_cucm-cli-reference-guide-1052/CUCM_BK_CA8D6D40_00_cucm-cli-reference-guide-1052_chapter_0110.html#CUCM_CL_S108E423_00
Manish
- Do rate helpful posts -
08-31-2015 04:04 AM
Hi Debasis,
Manish
08-31-2015 04:11 AM
one note:
After you enter the username, the system prompts you to enter the privilege level (0 or 1) and password for the new account. The privilege levels definitions are as follows:
Specifies an ordinary privilege level. Users with ordinary privileges can run CLI commands with privilege level 0 only.
Specifies an advanced privilege level. Users with advanced privileges can run CLI commands with privilege level 1 and below.
The administrator account that the system creates when Unified Communications Manager installs has a privilege level of 4. The administrator can run all commands in the CLI.
08-31-2015 04:08 AM
if I'm not mistaken, the user to SSH connection, must be the user the OS ADMIN!
