03-19-2011 04:33 AM - edited 03-16-2019 04:02 AM
I need step by step guide to configure SSO for Callmanager. I am able to find Cisco Doc, but not able to get configuration guide from OpenAM side.
I am looking for guide where it can discuss about ADS, Windows, OpenAM & Callmanager configuration.
Help in this regard is highly appreciated.
Thanks in advance.
Veera
03-19-2011 07:18 AM
Here's the white paper on how to configure everything: https://supportforums.cisco.com/click.jspa?searchID=25552149&objectType=102&objectID=14462
01-09-2013 10:03 PM
So I've gone through the white paper and on step 10.3.2 where you log into https://OPENAMSERVER:8443/opensso/UI/Login?module=MODULENAME and I'm getting authentication failed errors. Is there any logs I can start looking at to help find out why its failing?
04-04-2013 12:47 AM
Hi Joshua,
It's my first OpenAM integration and I have exactly the same issue. I followed all the steps of configuration and then tried to authenticate from a web browser to validate that the authentication works before going further:
https://openamserverfqdn:8443/opensso/UI/Login?module=CUCMUser
I got an error message "your authentication module is denied".
Did you figure out why you did wrong? Probably I did the same mistake?
Thank you for your help.
Yorick
