Community Helping Community
1286
Highlighted
sso. cucm. expressway
Hi all.
I have cucm and expressway installed for mra. All work fine. I want to enable sso just on cucm and don't want enable it on expressway. Is it supported configuration or i need enable sso on cucm ande expressway at the same time ?
15 REPLIES 15
VIP Mentor
SSO is enabled cluster wide
SSO is enabled cluster wide on CUCM. You can't enable or disable it on expressway. Once your cluster is enabled for SSO, jabber will automatically discover it through expressway.
Please rate all useful posts
I can enable and disable sso
I can enable and disable sso on expressway. See documentation for that product http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-5.pdf
VIP Mentor
Oh wao. I didn't even know
Deleted
Enthusiast
Hi Ayodeji
Hi Ayodeji
If SSO is enable on CUCM but not enable on expressway, users still be able to log in over Expressway MRA?
VIP Mentor
Yes definitely, SSO just wont
Yes definitely, SSO just wont be available and jabber will default to normal sign in.
HI Ayodeji.
HI Ayodeji.
How users will be able to login over MRA if they will not be ablle to acces to IdP server ?
Enthusiast
They will not
They will not
How about the other way
How about the other way around?
Can we enable SSO on Exp without enabling it on CUCM?
Pasha.
VIP Mentor
Pasha,
Pasha,
No you need to enable SSO on both CUCM and expressway-c/e for SSO to work over MRA. This is because once the client has been asserted at the edge by the expresway, CUCM still needs to verify from IdP server that the client is authroized for the request.
Please refer here for more details
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/admin_guide/Cisco-Expressway-Administrator-Guide-X8-5-1.pdf
Thanks Deji,
Thanks Deji,
I read the doc, i did notice it said IdP & CUCM should exchange SAML metadata, it just didn't explicitly say SSO should be active on CUCM. I understand it was implicit, i was just hoping that someone had different experience :)
Thanks again.
Enthusiast
Test it. If SSO is enable on
Test it. If SSO is enable on the CUCM cluster,it  needs to be enable on MRA or user will not be able to log on.and will get message SSO access denied.
VIP Mentor
Yes, this is correct. SSO
Yes, this is correct. SSO needs to be enabled on all infrastructure for Jabber to work
Enthusiast
Looks like my testing
Looks like my testing procedure was not really good after all :)
YES, it is possible to have SSO enable on CUCM/Unity and not-SSO enable on Express. Then your initial comment was right!.
VIP Mentor
Thank you for the update. I
Thank you for the update. I have learnt a lot from interacting with you, so thank you
Content for Community-Ad
FusionCharts will render here
