04-11-2016 08:17 AM - edited 03-17-2019 06:31 AM
I have a strange behavior while using SSO with CUCM and ADFS 3.0.
After my first configuration on CUCM 10.5 I had the issue that I were never redirected to the ADFS login page. After upgrading to Version 11 it worked perfectly. Now we had some changes with our internal CA and I reconfigured ADFS and did the same for CUCM SSO. So far so good, the SSO test works and all is good. But when I open the CUCM page (.../ccmadmin) I'll not getting redirected to the ADFS login page, like before on version 10.5.
Doing the same for ../ucmenduser or for my presenceserver it works without a problem.
Why doesn't the CUCM adminpage not redirect me to the login page? I checked the ADFS Server logs but no errors there so I guess the redirect fails sowmhow. But why does it works than for the other pages...
I've read that I will not get the login screen when my system is domain joined and I'm logged in into the domain. But I'm not 100% sure.
Anyone any idea where I can check or what I can check?
Eike
09-22-2016 12:39 PM
Eike, were you able to solve this? I've come across the same issue. SSO works on everything apart from the CUCM publisher admin page which never redirects.
09-29-2016 03:05 AM
Hi Sean,
no I had no luck. As I said already installing a patch or so fixed it. But I had the issue a couple times with my LAB CUCM here. I have no idea how to fix in another way.
Sorry
Eike
04-10-2017 05:40 AM
Hi all,
I have the exact same issue, but only on our Publisher. Not on Subscriber or - e.g. - SelfCar Portal.
Any Solutions?
Thanks!
Kind regards,
DrM
07-03-2017 06:12 PM
I have this also. Our cucxn (unity) sites work fine, the cucm (call manager) page refuses to SSO.
Everything else seems to be working fine, Jabber SSO etc. It's not a major issue but for some reason it really bugs me!
02-22-2018 05:52 PM
