Standard Local Route Group and Calling Party Transform Mask
rmv72
i've several device pools with own Local Route Group. I use for example one Route Pattern for all - 9.!
How to set for each Device Pool own Calling Party Transform Mask which send to voice gateway?
REgards,
Mike
3 Accepted Solutions
sumimanc
Do you know about these fields" Use Device Pool Calling Party Transformation CSS" on the gateway ??
Sumit
shrvaran
1. Create a partition - PT-Chicago-Calling, PT-NY-Calling
2. Associate them to Calling search spaces CSS-Chicago and CSS-NY respectively.
3. Associate the calling search spaces to the device pools
4. Under Calling party transformation whatever transformation patterns are available is affective with that device pool.
Yes you need to create separate calling party transformation patterns(in different partitions) for every device pool that exists on your CUCM. At the common route pattern 9.!, make sure you check this checkbox "Use Device Pool Calling Party Transformation CSS". This will ensure that when the route pattern is matched for outgoing calls, it will use the device pool settings(specifically 'Calling Party Transformation CSS' at the device pool should contain the partition containing the actual calling party transformation pattern) to select the calling party transformation pattern and hence the calling party number will be transformed accordingly.
Hope that answers your query.
Nitesh
PS:Please rate helpful posts
5 Replies 5
sumimanc
Sumit
sorry for delay...
Can you give me a little explanation..
Do i need to create "Calling Party Transformation Pattern Configuration"?
Nitesh
shrvaran
Thanks!
